Please bear with me to understand what I am looking for.
I want to build an on-grid solar system that will "help" my AC (the AC compressor system cooling my home when it's hot), by supplementing the power from the grid with solar-generated power.
To make it DIY-friendly and cheap:
- It should not use any batteries or battery controllers.
- It should continue "helping" my AC as much as it can, even when sun conditions are not great (e.g. cloudy sky, or when the sun starts setting down).
- It should never give power back to the grid. It should die when the grid power dies (or when the house main breaker is flipped off), and should start assisting again when the grid power comes back up. It should have no high voltage anywhere in it (or in the AC compressor) when the power is off. This way it's safe, and does NOT require main panel upgades, power meter upgrades, city permits, contracts with the utility company, etc.
- It should obviously waste all solar-generated power when the load (my AC) is off. Note: a more-advanced version of this could be made, with batteries, so that it will continue "helping" when the sun sets; I don't want to use batteries, myself, to keep this cheap and simple.
Obviously, such device can be used for just any load (not just AC compressor), e.g. it could be installed at a sub-panel, and help all appliances and loads that are being powered from the sub panel.
Why I need this: I am on a "EV2-A" time-of-use plan from PG&E in California. During peak hours (4 to 9 pm) the cost of power is 4 times! higher than off-peak hours. I want to reduce my energy consumption during peak hours, as much as I can.
Is there such device?
If not: can it be built?
Thank you!
Thank you!
