timselectric
- Feb 5, 2022
- 24,433
Correct this is the sole purpose of the grounding system, which is created by the N/G bond.I had thought , and I totally could be wrong, that the purpose of a ground-neutral bond in an inverter was to immediately allow a ground fault (a live wire is loose and accidentally touches the metal case of an appliance ) to complete the circuit back to source via the appliance ground cable that then connects to the neutral via the bond , and trips a breaker to disconnect the power quickly.
Also correct.Are you saying an inverter with no bond, but with a GFCI at the ac out, offers the same protection in the event of a ground fault as described above. ?
In fact, it is a higher level of protection.
