I will start off with I KNOW NOTHING. Only what I have learned off of youtube.
I want to connect my roof solar panels to a portable panel into the same solar charge controller.
2 100W solar panels on roof using MC4 branch connnector then go through the roof
That line coming from roof would be connected to a second MC4 branch connector then connected to Solar charger
I will use the second MC4 branch to connect to my portable panel to my roof panels
1 190W solar panel using MC4 to SAE adapter
plug that into the SAE wall port
then use SAE to MC4 and that would go into that 2nd MC4 branch
Will my roof panels still charge my battery even when the portable one is not connected?
Will I be losing amps by using all these connection?
2 100W is Rich solar
1 190W is Rich Solar
1 Epever MPPT Charge Controller 40A
2 MC4 Branch connectors
2 MC4 to SAE adapter
1 SAE wall port
I have attempted to draw it and if it works will be attached to this post. I have also inculded the specs of what I would be using.
100W
Specifications
190W
Specifications
THANKS for any help advise.
1 SAE wall port
100W
Specifications
- Maximum Power: 100W
- Maximum System Voltage: 1000V DC (UL)
- Optimum Operating Voltage (Vmp): 17.8V
- Open-Circuit Voltage (Voc): 21.2V
- Optimum Operating Current (Imp): 5.62A
- Short-Circuit Current (Isc): 6.02A
- Weight: 16.5 lbs
- Dimensions: 39.6 x 26.6x 1.4 inches
190W
Specifications
- Maximum Power(Pmax): 190W
- Maximum Power Voltage(Vmp): 20.4V
- Maximum Power Current(Imp): 9.31A
- Open Circuit Voltage(Voc): 24.3V
- Short Circuit Current(Isc): 9.86A
- Maximum System Voltage(Vmax): 1000V DC
- Weight: 26.5 lbs
- Dimensions: 58.7 x 26.8 x 1.4 in
