Hi,
I currently have a Sol-Ark 12K inverter (Grid-tied) installed with 10KW of solar panels. I have another set of panels on hand (4.5KW) that I would like to utilize. They are not compatible with the panels feeding the Sol-Ark, so I had the idea of adding a cheap Growatt inverter.
The Sol-Ark DOES backfeed to the grid, but the Growatt will not be backfeeding into the grid and its output will only be used to power a 240 volts miner.
I wasn't sure if there would be an issue with the main Sol-Ark inverter. I know I could add a second Sol-Ark inverter, but I really don't want to spend another $7K just to use the 4.5KW array.
Thanks
Thanks
