ericfx1984
- Oct 10, 2021
- 740
So I ordered some 230 amp hour cell and there was some miscommunication.. I was showed a video of the screw in terminals which, in the video had a flat area with a tapped hole allowing you to use the entire surface area of the battery pad
However, what arrived was a terminal significantly smaller that is welded to the pad with significantly less surface area
It makes me wonder if this is going to be a problem I plan to build two for US Banks and would like to be able to pull up to 200 amps from each Bank
Don't know if this is going to work
