I just finished charging my 8 EVE 105Ah cells in parallel to 3.4V, then 3.5V then finally 3.6V per cell with a rest in between steps. All seemed to be good at first, when I disconnected the charger they dropped from 3.6V to about 3.57V which I expected. I ran out of time last night to finish the fixture and cut the busbars so I left them overnight all connected in parallel. This morning I measured the pack voltage and it was about 3.54V. I measured again today about 8 hours later and the pack was at 3.537V.
I know they are in the knee of the curve and voltage changes with very little capacity change, but this seems a bit high of a self discharge. I would expect after the initial settling out the voltage would stay fairly stable.
Is this normal?
Next step is break down the pack and monitor each cell. I am hesitant to do this as 1) I don't want to leave the cells at 100% SoC for very long and 2) every time I remove and reinstall the nut on the stud I risk stripping the cell terminal threads.
Appreciate any input.
Is this normal?
