should I expect that there is conduit from the meter to the power panel that I can also piggyback on
If by piggyback on you mean run other cables in the same conduit…i would suspect there won’t be additional room in there.
So the disconnect would be near the exterior junction box at 9-o’clock with the meter?? That’s what they want? I’m assuming there is underground that feeds up into what looks like an exterior panel.
Because if you have the first incoming power at that meter / box, and that box has no disconnect then you can add one in it if it’s the kind of box I think it is. I’d expect there already is a disconnect/breaker in there?
@timselectric ?
So the disconnect is job#1- if there’s already a disconnect there, then if you connect behind that breaker or switch eith the solar then that’s solved.
Since you haven’t mentioned your latitude I cannot for sure say your batteries in a detached outbuilding will not be subject to <32*F but I’m assuming you are far enough south to not be at risk. That’s job #2.
Job #3 is simplification, but you may be past alternative location?
guessing you don’t want the array on the front lawn closest to the shed
don't know where you are in the world but are you planning to heat and cool the shed
The brown-roofed building that
appears to be either a gambrel- or shed-roof-flanked garage at 2-o’clock would be the best use, most efficient, and least expensive location for SCC/inverter unit and batteries. Then you could conduit directly to whatever box or junction that is at the right end of red line with 78.91 notation.
Job #3 would be to assure / install the breaker/feed from inverter to household entrance panel. And assure the panel is adequate for the combined inverter+grid (unless you are interrupting the ‘grid’ for 100% management of the grid by whatever the ‘inverter’ device you are installing is).
So there’s too many things we do not know. One of the actual electricians or EE’s should be able to verify if the disconnect near utility meter is allowed to either 1) isolate the structure completely or 2) needs to actually disconnect the solar regardless of the meter disconnect with a huge circuitous u-turn of the solar (which might be why you drew the batts/‘inverter’ at 10-o’clock?)
I maybe don’t understand all that you used for information in drawing it that way. Let us know
Either way, merry christmas
