Solar Trainiee
Hey everybody, A friend of mine has two spools of 10 AWG THHN Stranded Copper wire, 500 ft One Red and One Black. $150.00 for both. I tried to look up the information on the wire but this is all I could find: Thermoplastic-insulated copper wire with a nylon covering. Sizes 8 AWG through 1000 kcmil feature Cerrowire SLiPWire® Technology for fast and easy pulling in conduit. This 90°C, 600 volt building wire is for use in residential, commercial and industrial applications. Intended for use in accordance with the National Electrical Code® in both wet and dry locations. Gasoline and Oil Resistant II, The jacket is made of clear nylon (polyamide), Color coded, heat and moisture resistant PVC insulation. I would use it to wire and run from a ground mounted and some roof mounted solar Arrays to the inverter. I just don't want to use the wrong wire and have it start a fire in a yr. I've shopped for other wire and its says PV Wire, it's 90 C but 2000 volts and says Sun & UV light resistant. I just wanted to get some other opinions.
Alright, Thanks guys.
