What was the outcome of connecting all 8 cells to the isdt bg-8s to your 4s2P battery bank? I want to do the same for instant cell monitoring.
I have the ISDT 8T which is nearly identical.
Your ISDT 8S is expecting an 8S battery which is wired with a 9 wire balance wire loom.
The 1st pin is to the 8S battery negative post on cell 1.
2nd pin to positive cell 1
3rd pin to positive cell 2
9th pin to positive on cell 8
As such, anything that uses this 9 pin connector, expects an incremental voltage between pins 2 thru 9 to be roughly 3.2V higher.
So if you have this wired to a 2P4S battery, pin 2 and pin 3, when used against pin 1, will both read 3.2V.
This would cause a BMS to see cell 2 as having 0 voltage and shut down.
Why not just use a 4S balance wire set on your 2P4S battery? This is how its intended to work. Besides, you don't need to monitor individual cells in 2P because they will act as a single cell with the same voltage but doubled capacity.
