hi. i got a 12v 7w light bulb incandescent measured the solar cells again got exact same reading when trying to read the amps in series w/it. I also tried reading across. a used aa battery and got 6.6. so seems the meter is working. i have another simular meter. got same readings. could it be. i got 2 bad panels?
So you proved something is not right between both leads. If both panels are hooked in series on the roof with wire going down, any connection and wire could be bad.
If its just the panels at the MC4 leads, the only thing that could be wrong is the bypass diode could be busted. Ohm across the diode and should be very low amps one way and when you switch the leads, on open circuit.
If the wiring tested good, and the diodes tested good, the panel would be bad. If the panel is bad, I’d appreciate a description if anything was visually wrong or not. I watched a pretty long video testing a panel that went bad, and at the end he said he did not know why it was bad.
Here’s the inconclusive video but pretty good at the procedures:
