Setup my Daly BMS the other day and everything has been working ok. Cells are somewhat mismatched as one cell hits 3.6, while others are still 3.4. The BMS sucessfully shut down at high read while I was watching. I took everything apart, wired them in parallel, and let them sit with a low charge input for a day. Then wired in series again and started to charge again. High level cutoff happened when I was asleep, and the next day, I can only get 10v reading through BMS, but the battery pack is 13.6. I tried shorting the 2 pins, and tried shorting B- and P- for a second, but nothing. The first cell (BMS negative lead) is only reading 1.1v through the bms, but tested alone its 3.59. So the whole battery pack only reads 10.1v through the BMS, but reads 13.6 bypassing the BMS. Is my BMS fried? What should I try? Thanks guys!
