Hi all
I just recently mounted a new set up in my shed.
I was previously running a washing machine on a old AGM Deep cell which had been taken from a Truck hydraulic system hooked to a panel via cheap PWM I got with the Panel. This temp system ran the Machine without a problem for over 12 months
In comes my permanent install based on wills 400w system
100/50 Victron MPPT Smart Solar controller
100ah RENOGY SMART LITHIUM-IRON PHOSPHATE BATTERY
and a 1500/3000 pure sine wave inverter
Battery is charged and I tested the inverted with a number of power tools and it working fine.
Upon hooking up the Washing machine water pumps in however the agitator motor does not start. Plugged it into the mains worked fine. plugged into the invert no go.
I then plugged my shed fridge into the inverter and it worked fine.
I'm scratching my head. Any ideas.
Cheers
Scott
Cheers
Scott
