Castaway Camper
- Sep 15, 2021
- 18
First post here, but I've been reading you'll for sometime which has been invaluable for my recent off grid cabin build. Thanks ahead for any advise you may be able to share. My Overkill Solar 16S 48 Volt BMS is doing something strange. When charging the battery, cell #6 will cause battery to shut off due to cell over voltage, as soon as it does shut off, it shows all cells well within acceptable Delta instantly, and within acceptable voltage range. Conversely, when discharging cell #6 will show a significantly lower voltage than the others, to the point of shutting down the battery due to cell under voltage, once shut off, all cells are well within the acceptable Delta, then it automatically cuts itself on again and repeat, repeat, repeat. I was away for a couple weeks and when I reconnected to the BLU Tooth I apparently had over 31,000 BMS overvoltage times. I have checked all cable connections. Thanks in advance!
