hummmingbear
- Feb 8, 2022
- 172
I have a 4-battery packs with cells in 16S (EVE 280K) and am using the WatchMon-CORE kit with a CellMate-K9 for each pack. I have had issues with a few cells not staying balanced in different packs. What is confusing to me is the voltages batrium is reporting...if my pack voltage is 55.20 that would mean I should either be at 3.45 at each cell OR some cells should be above 3.45 and some cells should be below 3.45. In the screenshot below, you can see none of the cells are above 3.45 but there are 3-4 outliers below with the lowest at 3.38
I don't understand how that can be, and I'm a bit frustrated I can't get my cells in balance. I want to avoid having to open my pack and manually balance them. My charge controller is set to bring the pack up to 55.2V (3.45/cell) for 1-hour, and then go to float at 53.6. My batrium BMS is set to start balancing at 3.45, so any cell above 3.45 it will start using it's resistors to bring the cell(s) down.
I can't get these few cells back into balance for the life of me. What am I missing here? How can the pack be at 55.20 when not one cell is above 3.45 but multiple cells are below?
Any help/input appreciated, thank you.
