it was a battle....
100kwh-hunter
In one corner at 66 kilo the blue challenger for the title true dead weight....
You will laugh your behind off......
You fat bast**** I won.....
woof thats a porker of an inverter... not super knowledgable about victron how many watts is that monster? is it a LW with a large transformer built in?
Two straps. Why didn't I think of that?
I used single strap to lift a 140# Sunny Boy 15" high onto a pole. Using a block to support while unwinding strap ratchet for next part of lift.
Next time I did it I walked the thing up a ramp, only used strap last couple of inches.
One strap good, two straps better.
i used 4 basically.
2 big ones for faster lifting, than a small one to bring it more to the wall, a second small one to release the two big ones.
Now the tricky part.....
They can only go up, so the last centimeter i had to do it myself, before releasing.
It fitted like a glove.......
To get the tension off those straps i used a extra rope, going round the beam once.
tension a bit, release straps.
release rope a bit.
Grab a beer out of the cooler and make yourself a smoke.....enjoy.
Now my hard work is just starting.
A 3200 euro costing beast must be programmed, they really could not find a way to integrate something?!?!?nope you must buy a mk3 thingy.....
The MP15kva is working btw, still no grounding, attached to 360kw lifepo and feeding only a lifepo4 tester that consumes at the most 200w:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
isnt there a way around to avoid the mk3?
Block and tackle still works well but I finally got a lift that makes things so much easier especially when working with equipment in the hundreds of pounds.
I should have grabbed a few pics of when I had to move my ~400lb inverter
craned it off the deck of my old place using a forklift and some straps, what made it jank was the lift was at the bottom of 8 steps with the mast leaning way too far forward to do it.
having lift points above your wall mount equipment is a nice touch to any install. Definitely +1 to block and tackle. ratchet straps have no safe down direction, block n tackle gives you far better control
I just roll the dice and hope I don't get a hernia.
Haven't fumbled yet. It's a foolproof plan.
Well I gota hernia crimping some big lugs last year… thst why I went to a hydraulic one and won’t use the the other I have anymore… nope….I’m taking the easy way out for now… hernias are awfull to get over. Expensive and life disrupting…
Been there , done that…
No more..
Weight was a priority in my system planning.
The heaviest part of my system is the solar panels, at 50 lbs.
And I don't plan on picking them up, ever again.
I have some massive bifacial panels I put up last year on a pergola. Those were miserable to deal with. On top of the weight the size of them made them sort of floppy. I ended up rigging an electric host to a nearby tree.
I've really got to detail that build so you all can make fun of me for my terrible carpentry skills.
