Jackery Explorer 500 BMS identify/replace
Sandman614
Can anyone help identify the BMS in this Jackery Explorer 500 or a replacment. I've searched the part numbers on the board and browsed the usual suspects and haven't been able to find anything. For reference the part number: HTE042_BMS_P2, date: 2020-04-10, MARK2, chip part number: D502BB 507
Problem:
My friend ran the unit below 10% (big no no, according to Jackery), charged it with the AC plug and "it won't hold a charge" or "it will only work while plugged in". When I inspected it one cell was severely out of balance (1.88v) while the rest were moderately out of balance(3.83v - 4.08v).
Fix 1:
I balanced the cells with an active capacitive balancer. The severely out of balance cell is at 3.81v while the rest of the pack is at 3.83v.
Problem 2:
Same as Problem 1, it seems like the BMS isn't turning on it's output.
Fix 2:
New BMS with Balancing and Under Volage protection
Conclusion:
Jackery cheaped out on the BMS, no good Under Voltage protection or Balancing
Have you emailed Jackery re the BMS? Perhaps they can shed some light on a) the BMS and b) how to resolve the issue at hand.
Techman
