Jackery Explorer 5000 Plus questions & answers
Gaijin2
Texas
Jackery technical support has been great at answering questions as I try to figure out the optimal configuration for my house. Since at this time there isn't a lot of Explorer 5000 information out there yet, I thought I'd share the answers I've been getting. As of right now I have an E5000 and the Smart Transfer Switch, but haven't installed yet as I'm waiting on a permit from my AHJ.
1. Total Solar Input: The E5000 has three solar inputs: two DC8020 Low Voltage ("Low PV") inputs capable of up to 60V @ 10.5 amps, and a set of MC4 connectors ("High PV") capable of a range of 135-450 volts at up to 15 amps. However, those are the ranges, and not representative of the total maximum input. The Jackery charging system is capable of handling a maximum of up to 4,300 watts total.
2. No Excess Solar Throughput: Solar is used for charging batteries. If all the batteries are already full, what happens to any excess solar input? It ends up being wasted. The solar input doesn't get on-the-fly converted to AC output. The batteries' storage is converted to AC output, and as the battery is drawn down, the solar can replace what's been used, but only up to the battery's capacity. If you're ending up with full batteries and wasted solar, that's probably a good sign your solar array is oversized for your current situation, and you could use more batteries and increase the number of circuits the E5000 is powering to optimize your configuration.
3. Battery Charging Time: The E5000 has a 5kWh battery, and multiple possible inputs: HV solar, LV solar, AC wall power, and a direct connection to the Jackery Smart Transfer Switch, and it can use all these sources to charge the battery simultaneously (for example, if you had the AC wall power plugged in, that will deliver around 1800 watts, if you had an external DC source like a Chargeverter connected to the LV inputs that can deliver up to 1200 watts, and if you had a solar array on the HV inputs it could pull in wattage from there too). However, regardless of how many power sources you have and how much wattage they can deliver, the maximum charging wattage is 4300 watts. This applies for internal and external batteries. So with 4300 watts available to it, the Jackery can recharge its internal battery from 0 to 100% in 1.7 hours.
4. Charging Expansion Batteries: The E5000 has its own proprietary expansion battery, the 5kWh Jackery Battery Pack 5000 Plus (JBP5K for short). This is the only expansion battery that works with the Explorer 5000 Plus, and this battery works only with the Explorer 5000 Plus. You can connect up to five expansion batteries to an E5000. They all get charged by the same 4300 watt charging system in the E5000. As such, if you had a fully maxxed out system (J5000 + five external JBP5K batteries) and they were all completely empty, it would take just over 10 hours to charge them all to 100% if you had full power input (such as from the Smart Transfer Switch, or from maximized solar input). That would be 30kWh of storage.
5. Third Party Batteries: It is assumed unlikely that any third party battery manufacturer will be making an alternative expansion battery that uses the proprietary Jackery connection and communication protocol that the JBP5K uses. However, you could make use of an external battery to a limited degree, through the two Low PV inputs. Each input is capable of a maximum of 600W, so an external battery such as a server rack battery could feed each Jackery 5000 up to 1200 watts. A large battery like an EG4 or Ruixu Wallmount could recharge an E5000 almost three times overnight, keeping 1.2kWh of electrical service going for around 14 hours until the sun comes up or the grid comes back on. That's not a ton of power, but considering that competitors like the Anker F3800 only provide a maximum of 2400 watts of solar/DC input in total, 1200 watts is not nothing. The advantage to a third party battery is cost, clearly: a 5kWh server rack battery is around half the cost of a 5kWh JBP5K. But there are tradeoffs. You get only 1200 watts of input from a 3rd party battery, but the JBP5K is capable of feeding the E5000 a full 7,200 watts at a time. Plus you'd have to figure out a way to charge the 3rd party battery; maybe a Chargeverter to charge it from the grid, or its own dedicated solar array and solar charge controller; the JBP5K charges from the E5000. And the JBP5K takes up a lot less space than a server rack battery, but the EG4 and Ruixu Wallmount batteries are quite compact and rival the JBP5K for space optimization.
6. High PV/Low PV Priority: If you had an external 3rd party battery connected to the LV inputs, and a solar array connected to the HV inputs, the E5000 will prioritize drawing energy from the HV (High PV) inputs first. That means if you had a sufficient solar array to keep the E5000 (and any connected JBP5K batteries) full, your external 3rd party battery would remain untouched throughout the day, and would only begin to be accessed when your HV solar input is insufficient to meet the load that the E5000 is supplying.
7. Can You Stack Two Explorer 5000s? If you had limited floor space but plenty of vertical space (such as in a narrow closet), yes you can stack one E5000 on top of the other, and you can stack batteries on each other. Keep in mind that each unit and battery has fans and needs air circulation space, so you can't put expansion batteries too close to the E5000 or to each other in such a way that those vents get blocked. You can stack the batteries vertically, just make sure each stack has room to breathe.
8. How Much Can The Smart Transfer Switch Power? The Smart Transfer Switch (STS) can handle 100 amps at 240V. It can distribute that current through up to 12 circuits to the house (up to a max of 60 amps of flow-through power) and to up to two E5000 units (16.7 amps each, or 4008 watts). A single E5000 can feed the STS circuits at a rate of 30 amps, two E5000s together can meet the full 60 amp load potential of the STS.
9. Can You Connect Two E5000s Together Without The Smart Transfer Switch? Not at this time, no; connecting two together requires the STS. The Anker F3800 can use a Double Power Hub to connect two F3800s together to gain a single 50A outlet and split-phase power. The E5000 already has 240V output on its own, it doesn't need to be paired to gain that (although maximum output of a single unit is 30 amps.) When paired with the STS, two E5000s output 60 amps of 240V split-phase. So far as I can discern, Jackery has no plans to introduce something like the Double Power Hub.
10. What Wire Gauge Needed To Connect STS To Home Power Panel? There's a video on Jackery's Smart Transfer Switch page, a review from Electric Pro Academy that shows installation of the STS, and in it he describes his logic in using 6 AWG wire to connect the STS to the main panel. But Jackery's STS owner's manual calls for 2 AWG. Which should you use? Definitely follow Jackery's recommendation of 2 AWG. Electric Pro Academy did a very limited installation; he only installed one circuit in the transfer switch and only connected one E5000 to the STS. As such, the current draw was minimal (well below 40 amps); he even used 3/4" conduit. And while he did the calculation for the wire for the 60A load correctly, I think he didn't count on the additional 16.7A power draw each connected E5000 will pull from the STS, on top of the home load! But in a real-world full home installation, where the STS is drawing 100 amps from the main panel and powering up to 12 circuits at 60A and up to two E5000s at 16.7A each, you're going to need 2 AWG wire. That 6 AWG was fine for one circuit and one E5000, but a full home installation needs a 100 amp breaker, appropriately-sized wire and a much larger conduit to handle all the conductors for the 12 circuits, more like 1.5" to 2" conduit. I think Electric Pro Academy's review/video is overall excellent and thorough, but I think he made a mistake in choosing 6 AWG wire and I strongly urge STS installers to use Jackery's recommendation of 2 AWG.
11. Can You Use a 120V Generator With The E5000 Or The STS? I've got a generator inlet with interlock on my main power panel, and I have an old 120V, 23Amp generator. It outputs 120V AC on a 30-amp RV outlet, which powers my whole main panel's 120V circuits on both legs, but I have to shut off the 30A and MWBC circuits first. Can you use a generator like this to recharge the E5000 during an extended power outage? This question is not definitively answered yet, I will update when I receive the final answer. My guess is that you cannot use a 120V generator with the STS through a generator inlet, since the STS specifications sheet specifically calls for split-phase power. But I believe you could recharge the E5000 from a 120V generator; you'd just have to connect the generator output directly to the E5000's 120V AC input socket. That should work even with the E5000 connected to the STS, but it means you'd get a maximum of only 1800 watts of charging power, so it'll take 3.5 hours to recharge the E5000's battery. If you want the quickest recharging time, you'll almost certainly need a 240V generator with proper 240V output feeding a 30A or 50A generator inlet with interlock on your main panel.
I have recently installed STS with two explorer 5000 plus. In summary this is what I have gone with.
1) 2AWG wire to connect to the main panel with 100AM circuit breaker. The STS also has a built in 100AMP circuit breaker.
2) It takes up generic circuit breaker but I have used square D home line to provide load to the house circuites (reconfigured from main panel to this STS)
2) Two jackery explore 5000 plus
3) so when operating with the grid, it can draw up to 100AMP in situation where it is charging the batteries but still powering the house circuit.
4) when running off the batteries (which I do during high peak hours) the maximum draw is 60AMP (30amp off each of the 5000 plus), it does a nice job of drawing equally from each battery bank ie each of the 5000 plus.
5) the jackery app has a very nice intuitive circuit.
You won't be able to charge the batteries via a generator when it's plugged into the STS. It throws an error
Is there a trick to this? I tried setting mine up and it discharges according to the schedule no problem, but it does not charge back up during the charge schedule... I have no clue what's going on. Maybe it's an app setting that I'm missing?? If you have any tips. let me know.
Wow! Thanks for the terrific write up!
I would love to understand more about the low voltage solar inputs on the Jackery plus systems. I have a 2000+ with a 2000+ expansion battery and a Jackery rep told me that I shouldn’t attach solar panels to the expansion battery of voltages different to those that may be connected to the Explorer 2000+ when the units are tied together with the expansion cable.
That strikes me as strange since the units can obviously be independently charged with sources of different voltages when not tied to each other. I understand why different voltage panels shouldn’t be attached to the same unit but I am surprised to learn that there is no isolation between the unit inputs through the expansion cable. It would be nice to see the schematic for the input circuits to know if there really is no isolation between those inputs and the expansion ports. If anyone has any insight into how the input ports and expansion ports are designed on these units I’d love to learn more. Thanks.
I don't know anything about the 2000+, so I can't answer. Just reading the expansion battery's manual it certainly doesn't give any indication that I saw that would require you to use different voltages for the main unit vs the expansion battery.
The only thing I can tell you is that Jackery repeatedly says you should only use their solar panels, and they say that it's because they can't guarantee the performance with some other manufacturer's panels. And if you were to supply different voltage solar input to the 2000+ than you supply to the expansion battery, well, that kind of admits right there that one or the other is using non-Jackery panels, right? So I would expect them to get squishy when you start talking about non-Jackery solar panels. Heck, my 5000+ has "MC4" connectors and can supposedly work with all manner of solar panels and arrays, but they repeatedly, repeatedly tried to tell me that I should be using Jackery panels with the DC8020 connector. That appears to be their go-to line.
So my unverified suspicion is that it will work just fine, they just really wish you'd buy their 3x-the-cost Jackery panels instead of some other manufacturer's 1/3-the-cost panels.
BUT -- that's just a suspicion from never having worked with that product. The only way you'll know for sure if it'll work is to ask other 2000+ owners what their experience has been, or just try it yourself. My experience with them is that they will never reveal the tiniest bit of any information on the internal workings, but you can always try asking again - their support line is staffed by many different support staff, you might get someone else who gives you a different answer, or, if you're not satisfied with the answer they give, you can ask the question in a more specific precise manner; I've found that that technique usually gets the question escalated to a higher team and you have a better chance of getting an answer. Even then there's no guarantee it'll be the right answer; I've gotten a 180 degree different answer than someone else got, so... yeah, go for it, but good luck!
Thanks for the excellent and detailed writeup. I have a followup question regarding point High PV/Low PV Priority: If you had an external 3rd party battery connected to the LV inputs, and a solar array connected to the HV inputs, the E5000 will prioritize drawing energy from the HV (High PV) inputs first. That means if you had a sufficient solar array to keep the E5000 (and any connected JBP5K batteries) full, your external 3rd party battery would remain untouched throughout the day, and would only begin to be accessed when your HV solar input is insufficient to meet the load that the E5000 is supplying.
Here is my question: You had mentioned in another port that the High and Low PV input are only used to charge the batteries and do not do power conversion from DC to AC on the fly. Just curious how the 3rd party battery will be able to help with powering the load. I assumed it will help with charging E5000. Are you saying that while E5000 is charging, it can also convert stored DC to AC to power the load?
There are conflicting tech support messages about the power conversion on the fly. The tech support answer I received was that DC input was only for recharging and once the battery is at 100% any further solar input is wasted, but someone else received an answer saying that DC input is prioritized to recharge the battery but once the battery is at 100% then further DC input is used first to power the load.
Unfortunately I've seen another report where a guy asked Jackery support a question two different times and got two different answers. The list as I wrote it is the answers that I was given. As I get a chance to verify the answers I'll update the list.
That report I wrote is based on the tech support answers I have received. However, there are conflicting tech support messages about the power conversion on the fly. The tech support answer I received was that DC input was only for recharging and once the battery is at 100% any further DC input is wasted, but someone else received an answer saying that DC input is prioritized to recharge the battery but once the battery is at 100% then further DC input is used to power the load.
So we're going to need some testing to find out.
Would the 5000 Plus work plugging in to a neutral switching manual transfer switch (Generac 6854)? I use that switch with my F-150 Powerboost and it runs all the circuits on the 6854 but I am looking for something that can handle shorter outages before I hook up the truck generator or the truck is away.
I got a response from Jackery that the 5000 is compatible for anyone else looking for this info:
Kevin (Jackery Support)<hello@jackery.com>
To:You
Thu 2/27/2025 9:36 AM
Thank you for reaching out, Joe.
Yes, the Jackery Explorer 5000 Plus is compatible with a neutral switching manual transfer switch. It can be safely integrated into your system to provide backup power when needed.
If you have any specific installation questions or need further assistance, feel free to reach out.
Thank you.
Best Regards,
Team Jackery
Has anyone had any success hooking up the Jackery STS to a 200 amp service?
I connected my STS to my 200 A main panel, with a 100 A breaker using 2 awg wire as recommended by Jackery and noted above. Obviously, no issues. I think this is what you are asking about.
If you are talking about pulling 200 A of load through the STS, I don't think that'd work. The output loads from the STS are slightly unclear: I think the website might say it supports 60 A, but they recommend limiting it to 30 A with one E5000. I have emergency heating on my furnace which needs 60 A, they noted the STS will do a pass through of 60 A when on grid, but it needs to be limited to 30 A when running on the battery or it will trip the inverter in the E5000. Specifically, here's what I asked:
...it is possible to supply power from the grid via the STS even if it exceed the 30A limit, although, we still do not recommend this. Our official recommendation is to never put loads of more than 30A on the circuits of the STS.
Even with 2x E5000s, you can't power anything higher than 30 A while on battery per Jackery. I'm not sure how this works electrically, but they stated:
The two 5000Plus units will generate 60A of input, but the output cannot be greater than 30A.
This is because the 14400W will be split between the two E5000Plus units, so each unit supports a maximum of 30A of output.
Hopefully this helps!
Agreed, an STS on a 200A panel should have no problems. My main panel service is 150A and I'm putting an STS on it and anticipate no problems.
It definitely will not. The STS instructions clearly state to use a 100A breaker, like you did. If someone needed 200A of STS backup, that would require using a second STS.
That sounds curious... well, let's clarify one thing first: the STS can never power any particular circuit higher than 30A. The STS only supports circuit breakers up to but not exceeding 30A. So even if you had 2 E5000's, you still can't power a 40A or 50A or 60A circuit. That part is clear, and is unrelated to whether it's on the grid or on battery power.
But the idea that the total output of the STS is 30A while on battery? That simply can't be correct, can it? What's the point of of adding a second E5000+ if the STS won't use it? I think the answer you got from Jackery support just isn't right (it wouldn't be the first time!) The spec sheet is written a tad confusingly, but I think the preponderance of evidence shows that you should fully expect two E5000+ units to deliver 60A to the STS and the STS to deliver all of that 60A battery-supplied current out to the home load.
According to the STS specifications, it can input 100A from the grid, or 60A from the power stations. That 60A must be from using two, because each individual 5000+ can only output 30A as said before. So when on battery power, total power flow into the STS is either 30A or 60A depending on whether you have one or two.
The next line in the spec sheet is probably where the confusion arises: it says the STS's maximum output current is "60A Home Load / 33.4A Power Station". I am presuming that the tech support person you talked to interpreted that to mean "60A when powered from the grid, but only 33.4A when powered from the E5000+". But that simply has to be hogwash, it makes zero sense, and I'll show you why in the math below.
First, the terminology used is "60A Home Load". Load is a well-established term to mean the current draw by a system, and "Home Load" means output to the home. It is outputting 60A to the home. Then it says "/ 33.4A Power Station". That cannot mean 33.4A "when drawing from a power station", because it's already said that 60A is going to the home load, and it's in the same sentence, so I say it means the STS can output simultaneously a max of 60A to the home load and a max of 33.4A to all connected power stations". The whole line is about STS output.
Now, the math: 33.4A when powered from the E5000+ is an absurd number. Why? Well, the E5000+ outputs 7200W continuous, which is 30A at 240V. So why would the STS be allowed to output 33.4 when powered by battery? Where does the 3.4 come from? Are they saying that adding a second E5000+ would only increase the output to the home load by 3.4A? Can't be. That's makes zero sense.
Instead, please consider this interpretation: the STS's maximum output is "60A to the home load, and 33.4A to the power stations." I have had extensive confirmation from Jackery that the E5000+'s charging infrastructure supports an absolute maximum of 4000 watts, whether from AC or solar input or STS or even all 3 combined. 4000 watts @ 240V = 16.7 amps. So when the STS is on grid power, it can pass 60A from the grid out to the home load, and in addition, it can pass 16.7A to each connected E5000+ to recharge them. So if both your E5000+ units are depleted and the grid comes back on, the STS will output a total of 99.4 amps: 60A to the grid, 16.7A to E5000+ #1, and 16.7A to E5000+ #2. A total of 99.4 amps being output. Which explains very clearly why the Jackery STS installation instructions require a 100A breaker.
Under this interpretation (which I believe to be correct) there's no reason the STS would be limited to 33.4A output when connected by battery. Two E5000+ units feed a total of 60A to the STS, and the STS is designed to output a max of 60A, so under this interpretation it all makes sense and the math is mathing.
Yep - that's my understanding as well. Effectively, the STS is a 60A subpanel, but you might be able to get (100A - 16.7A) of effective loads out of it if you are only using one E5000+. Anyway, it's good enough confirmation for me that I'm not going to overload the bus bars in the E5000+ by putting a 40A load on it.
This was my original understanding also. I'm wondering if instead of synchronizing the 60 Hz sine wave from each E5000+ to get 240V/60A, they instead split they do something funky like have the left L1/L2 outputs connected to the E5000+ on AC1 and the right L1/L2 outputs connected to the E5000+ on AC2.
At the end-of-the-day, I've disabled the largest load (heat coils on my furnace) via a built-in relay when I'm on battery, thus keeping everything under the 30 A max of one E5000+.
