I've had solar hooked up for about five days now, and everything has behaved perfectly and exactly as I would expect and want. I have a 550w panel plugged into each LPV port and a 3.6k array plugged into the HPV. I have seen as much as 3800 watts of charging, not bad for mid-October. The 5000+ is on firmware version 1.3.
Then today happened. No idea what happened, but I got hit with two F6 errors, and an F0, and the HPV shut itself off. I couldn't power off the 5000+ either. The app said to disconnect the load (there was no load) and a communication error and whatever else.
Coincidentally(?) there was a red dot on the app in the upper right icon, which said there was a firmware update available. Curious.
I turned off the HPV, disconnected the LPVs, and disconnected from the STS. Doing that, I was finally able to power the unit off. After resetting it and installing the new 1.4 firmware that it notified me about, everything is working again.
No idea what happened, why the sudden onset of errors, and it's curious as to why there was a firmware update available at that exact same time. But it's back in action.
Observations after nearly a year of 5000+/STS usage and five days of full solar:
1. LPV Is The Way.
Jackery's been making LPV power stations for years, and the 5000+ is their first (and, IINM, still their only) HPV product. Pretty much all the complaints we've seen about system behavior have been tied to the use of the HPVs. While I think that those issues are likely now resolved with the latest firmware updates, I gotta say, the LPV is solid. Even when I was having the F6-fest this morning, the LPVs just kept churning away. They were only delivering about 130 watts in total (those are West-facing panels, not too productive in the morning!), but they kept working through all the errors and efforts to fix them. They just work.
I think it's wise practice to have the LPVs maxxed out on your 5000+. It's just great redundancy if nothing else. If you've already got a 4k array of 10 400-watt panels plugged in the HPV, you might want to consider if you can detach a couple of panels from that string and route each of them to an LPV input. You'll still have 4000 watts, but now you'll have redundancy, and if for any reason your HPV goes down or hiccups or whatever, you'll still have that reliable LPV quaffing 800 watts. If you're designing a new system, I'd recommend putting in a couple of 550-600W panels so you can max out the LPV. Just remember the cardinal rule: if you're using both LPV ports, they need to be fed from identical sources. Don't put a 400w on one LPV and a 600W on the other, use either two 400W or two 600W panels.
2. Wasted Solar. My 5000+ is connected to a potential of 4700 watts of solar (3.6k HPV and 1.1k LPV). With that, I find that a tremendous percentage of my solar is just wasted. The 5000+ is set up to discharge all the time, with a 20% reserve for emergencies. Almost all of my household circuits are on the STS (but not the big energy hogs, the electric dryer and the whole-house air conditioning), and during normal everyday living it uses between 300 and 1100 watts of usage, depending on if the whole-house fan is blowing or the refrigerator compressor is running.
So the plan was for the sun to keep the 5000+ charged all day, and then the 5000+ battery discharges all night. With usage around 400 watts, I figured I'd get 11 hours of battery. But the reality is: the solar charges the 5000+ up within a few hours of the sun coming up, and then for the rest of the day the incoming solar is just thrown away. Once the battery hits 100%, the HPV and LPV inputs are shut off. And will stay off, until the battery is drained down to 99%, at which point the 5000+ turns on the solar inputs and I see it charge itself with 3000+ watts for about 30 seconds, and then when at 100% it shuts off again.
Over the course of a full day, the 5000+ generates about 10kWh of solar power. The arrays it's connected to are capable of 4700w and we get about 4.5 hours of peak sun during October here, so the panels are capable of generating up to 22kWh of power daily, but the 5000+ is only able to utilize less than half that. If we were in June, we get 5.5 hours of peak sun, so the panels should be generating up to 26kWh, but the 5000+ will still only be able to use about 10.
And I'm finding that the battery in the 5000+ isn't lasting nearly as long as I thought; I guess that blower fan in the HVAC is running a lot more than I thought. The 5000+ battery is generally drained down to the backup reserve by maybe 11:00 p.m., so we go back to the grid after that, and it sits there until the sun kicks in the next morning. And I mourn the loss of that wasted solar.
The only ways out of this is more batteries, and more usage. If I moved the whole house A/C onto the STS, I probably wouldn't have any wasted solar, but the battery wouldn't last more than an hour at that rate. Instead, if I got an expansion battery, that would cut my wasted solar to about half, and the system might be able to last through the night, so that sounds good, but -- those batteries are ridiculously priced. At $999 I'd buy one, but at $2500 it's too much for what you get, and there are what I consider to be much better alternative solutions.
3. Instead Of An Expansion Battery...
The Explorer 5000+ is going for around $2500 on a good day when there's a sale and you use the VIP7 or OFFER7 coupon, but an expansion battery is also $2500! That's absurd. And I've never seen the price drop even a dollar on those batteries. The only way to get a lower price is to buy it as an add-on battery ($2099), you add a 5000+ to your cart and add an expansion battery, then delete the 5000+, and you'll get the $2099 price. But even then, and with the 7% coupon, $1952 is the lowest I've seen them. Frankly it makes more sense to me to buy a second 5000+ than it does to buy an expansion battery. With a second 5000+ you get double the battery, double the solar input, another 7200w inverter, you upgrade your STS to 60A output, and you get redundancy. Way better value than an expansion battery.
To me it makes a lot of sense, if staying within the Jackery ecosystem, to just get the second 5000+. Only substantial difference is that you'd have to split up your solar array between them, since solar connected to one 5000+ cannot be seen by the other, so you'd split that 4000 watt array in half and feed each of them 2000 watts. And with 60A of STS, now it becomes much more practical to move the whole-house A/C onto the STS, so there really shouldn't be any wasted solar at all.
But I'm going a different way. For just $2,000 I got a GrandTech SRNE SEI-12K-UPRO whole-house all-in-one (AIO) inverter. I'm a big fan of redundant systems, so adding this inverter lets me power my whole electrical panel (including the STS) from up to 9k of solar. Any otherwise-wasted solar can be sold back to the grid (at cheap rates, yes, but better than being wasted). And high-quality UL-listed batteries for the AIO are less than half the price per kWh than the Jackery batteries, and if you're comfortable using unlisted batteries you can get as much battery storage as three Jackery expansion batteries ($7,500 worth) for about $1,800.
I put 9.4k of solar on the roof with the intention of having two 4.7k systems for two Explorer 5000+ units. But with the SRNE AIO, it makes more sense to feed the SRNE about 7.2k of solar, and give my one 5000+ about 2.2k. That way the 5000+ should still be able to finish the day with a basically full battery, but none of that 9.4k will be wasted. The big inverter will easily handle the dryer, the A/C, any other miscellaneous circuits, and can sell excess power back to the PoCo. But the fun part is, because the AIO is feeding the main panel, the STS will think it's "the grid". So if I need to charge the 5000+ from "the grid", it'll actually be charging from the solar output of the AIO. The 5000+ system becomes grid-independent. And it's still a portable power station that can be disconnected and taken other places and used on trips or job sites or whatever. While the 5000+ is away, the STS will get its energy from "the grid", which will actually still be solar during the day and stored solar (from the big battery) during the night. And if anything ever goes haywire with the grid or half my solar array or the big AIO inverter, I still have a completely independent Jackery grid with its own solar, its own battery, its own inverter, to serve the purpose I originally got it for: emergency backup and power outages. And if the Jackery ever goes HPV-crazy, my house's power needs are still fully covered by the AIO and solar.
Anyway, sorry for the encyclopedia-length post, these are just my takeaways from having a 5000+/STS for most of a year and finally getting solar hooked up. My plans have been drastically accelerated due to the expiring solar credits in a couple of months, as I'm sure many of you are feeling too.
1. LPV Is The Way.
