G GaryVolt New Member Joined Jan 17, 2021 Messages 18 Jun 19, 2022 #1 Can Some one tell me why my JBD 7s - 20s 200amp BMS. Is oscillating "opening and closing" the main contactor when I charge it??
John Frum Tell me your problems Joined Nov 30, 2019 Messages 15,234 Jun 19, 2022 #2 GaryVolt said: Can Some one tell me why my JBD 7s - 20s 200amp BMS. Is oscillating "opening and closing" the main contactor when I charge it?? Click to expand... Could it be opening the contactor on cell over-voltage then the high cell settles and the contactor closes?
John Frum Tell me your problems Joined Nov 30, 2019 Messages 15,234 Jun 19, 2022 #3 smoothJoey said: Could it be opening the contactor on cell over-voltage then the high cell settles and the contactor closes? Click to expand... Guess it could also be over-current.
G GaryVolt New Member Joined Jan 17, 2021 Messages 18 Jun 19, 2022 #4 No the it's not connected to anything and I was charging it to at 10 amps
John Frum Tell me your problems Joined Nov 30, 2019 Messages 15,234 Jun 19, 2022 #5 GaryVolt said: No the it's not connected to anything and I was charging it to at 10 amps Click to expand... Which of my posts are you replying to? Is your charger bypassing the contactor?
G GaryVolt New Member Joined Jan 17, 2021 Messages 18 Jun 19, 2022 #6 The only way I can charger is to bypass the contactor. All the cells are pretty even they are with in .02 of each other. I don't see any over temp, over current issues. Last edited: Jun 19, 2022
G GaryVolt New Member Joined Jan 17, 2021 Messages 18 Jun 19, 2022 #7 Here's a screenshot Attachments Screenshot_20220619-144008.png 376.4 KB · Views: 28
7 740GLE Solar Wizard Joined Apr 30, 2021 Messages 3,392 Location NH Jun 19, 2022 #8 What kind of cell type are happy at that voltage? Is the BMS configured for that type of cells? Post up screen shot of the parameters of the BMS.
G GaryVolt New Member Joined Jan 17, 2021 Messages 18 Jun 20, 2022 #9 There 4.2volt cells I believe the bms is faulty.
J justgary Solar Addict Joined Jan 1, 2022 Messages 982 Jun 20, 2022 #10 GaryVolt said: There 4.2volt cells I believe the bms is faulty. Click to expand... Do you have it wired correctly? How many cells do you have, and what type are they?
