Hey All, first post. Exciting, bought 24 Eve LF280K and 3 JBD AP20S003S 200A bms from Docan Technology, Houston, in March. Got 3 8S strings operating w BMS, 1 installed replacing 3rd set of L16s in existing 20yr+ off grid room temp home system. Operating per Eve datasheet 90%-10%, charging to 26.6v/3.3v/cell. Overnight use of 30-70ah measured by Trace Meter TM500 w/Deltec shunt. 60ah commonly, just over 20% of 280ah string. Don't understand why every morning string voltage is 26.1v/3.26v/cell. Going from 90%soc to 35%soc is 55% reduction instead of expected 20%. Haven't been successful w/bluetooth, different post later, so stock, no programming changes, no disconnects, BMS just sits there, as it should, totally within operating parameters,...balancing? JBD bms datasheet shows 100ma@3.32v, 180@3.35v, and 260ma@3.38v, less than results showing. These have the contactor, coil only 35ma typically/50ma max, maybe 1ah overnight? Finally got other 2 strings added, 840ah and 3bms total and the results are unchanged 26.1v/3.26v/cell every morning. Having 840ah meant to carry you through several days of cloudy MT weather is lost when you are down to 35% every morning and last night only used 29ah, 31ah after 2 cups of jo! They do balance, cells within .01v at any soc. Trace meter 20yr trouble free, xchecked w/multiple digital voms, all charge/discharge goes through meter/shunt except what is internal to the bms units. At a loss, thinking of the wealth of knowledge here, surely someone has had similar experiences? Any ideas? Disable balancing except for once/mo? My thanks in advance.
