While you could use the BMS LVD like that, it may work better to put in something like the Victron Battery Protect to cut off the loads at 12.0 volts. You would not use the Battery Protect on the circuit to the inverter.
I looked up the Victron Battery Protect and it looks like it might do the trick so downloaded the manual. I am sure that there must be a way to set the cutoff voltage, but the manual doesn't say anything about that. How do you program it? It does not have Bluetooth which would be the obvious method.While you could use the BMS LVD like that, it may work better to put in something like the Victron Battery Protect to cut off the loads at 12.0 volts. You would not use the Battery Protect on the circuit to the inverter.
Yes, In the Bluetooth app there are several presets. In addition, there is a "User Defined' setting that allows you to set it to whatever you want.It does not have Bluetooth which would be the obvious method.
I find the balance wires on the JBD 200A BMS to be extremely sensitive to any movement. As I was installing elements around the lifepo4 system I would get alarms from the BMS for over or under current conditions. This is a few weeks post install. After a lot of trouble-shooting jiggling one of the balance leads restored the readings between two cells. I may have brushed the wire with my hand, but never more than that. Are there heavier duty balance wires available? Am I the only one with this issue? thanks
Get it working then put hot glue on the connector where the wires go in.Sounds like you have a bad connection.
I have had problems getting any wire less than 18-guage to make a good crimp connection. I usually strip twice as long a section as needed for the depth of the terminal and bend it back on itself to double the diameter of the wire. I also use shrink tubing with adhesive over the connection to provide additional strain relieve.
JBD didn't supply already manufactured ring terminals on any BMS that I have purchased from them. Sounds like your vendor did a poor job of testing.The balancing wires and connectors are all pre-made with the JBD BMS. There is no strain on the wires. I may need to redo the connector. Thanks
good find but those are 1/4" - and it's hard to find bigger, in general.I suggest part number 11A28016.
so would need to snip the rings or drill and tap the busbars - which I did anyway ?
you're right - 1/4" should fit m6 ok. I was thinking of another issue, oopsSounds like a very non-standard cell terminal. The one I suggested works well for 1/4 inch or M6.
this approach has been fruitful for me in the past.Get it working then put hot glue on the connector where the wires go in.
Overkill BMSs are JBD.Hi all,
can anyone tell me if there is any reason to prefer JBD app over the Overkill Solar app for monitoring and controlling the JBD BMS?
thanks
Agreed, but both JBD and Overkill have an app. Is there a problem with either one?Overkill BMSs are JBD.
Overkill is in the USA and they provide very good support.
