I have two sealed 12v x 480Ah packs that have this 200A JBD BMS and they seem to be completely unable to balance the pack. They are in a sealed case so I cannot open them to do anything to help the balance by charging or discharging individual cells. I have tried charge balance on and off but the low cell never seems to make any gains. If I try to charge them at anything greater than 14.1v I hit OVP with one cell at 3.65 and the low cell still at 3.37.
Any ideas on how to get this pack to balance?
Since they are the same BMS I presume the app is the same.Agreed, but both JBD and Overkill have an app. Is there a problem with either one?
As long as the delta is trending down with repeated cycles the battery is becoming more balanced.I have two sealed 12v x 480Ah packs that have this 200A JBD BMS and they seem to be completely unable to balance the pack. They are in a sealed case so I cannot open them to do anything to help the balance by charging or discharging individual cells. I have tried charge balance on and off but the low cell never seems to make any gains. If I try to charge them at anything greater than 14.1v I hit OVP with one cell at 3.65 and the low cell still at 3.37.
Here are my settings.As long as the delta is trending down with repeated cycles the battery is becoming more balanced.
To help that along set the BMS to balance regardless whether it is charging or not.
The make the absorption timer longer.
So set balance to activate at ~3.4 volts per.
Make sure your float voltage is <3.4 volts per.
Set the absorption duration longer to get the passive balancer longer to work while the cells are held in the high knee.
Its a bit more stress on the cells but its all you can really do.
If you start getting cell over-voltages you will have to lower the charge voltage even more.
It may not be the BMS. It could be a less than healthy cell.
With the battery voltage down from the 14.1 volts that is tripping you up, charge with fewer amps. That may allow the high cell more time before it hits 3.65, which will allow the low cell to come up further. Balancing usually doesn't happen until 14.2 volts, but that threshold is a parameter in the BMS that can be changed. You could try lowering, but only to get past the initial balance.
Do you have the two batteries in parallel or series? (since you said 14.1 v charge, you probably have them in parallel) If it's series then that is part of your problem. Disconnect the batteries and charge them individually.
That is pointlessly low.Here are my settings.
- I have balance turning on at 3.34v
good.
- Charge balance off (static balancing)
Why are you disabling the current paths?
- I have charge to 14.1v and then turned off both charging and discharge so that the cells are static except for the balance current.
You want to use absorption voltage to hold the cells in the high knee so that the balancer can actually perform a top balance.
- after 25-minutes, the low cell has dropped 11mv and the high cell has dropped 82mv and the delta has gone from 211mv to 140mv. So maybe it is working. I will let it run until the delta quits dropping and then charge it back up ot OVP and see if the next cycle is better.
3.34v was what I needed to go to in order to keep the static balancing going when the float voltage was set at 13.5vThat is pointlessly low.
What is your float voltage?
good.
Seems like you are on track for success. The balancing on a JBD is super slow, so it will take days and weeks of eeking it along like that.Here is today's results.
Here is where I was after balancing all night for about 24 hours. The delta had dropped to 59mv.
I then recharged it to 14.1v again and this time the delta is 182mv with the lowest cell up to 3.421v from the previous 3.375v & the highest cell down to 3.603v from the previous 3.581v This is the first time I have seen the low cell over 3.4v.
Especially true given that my other battery has a JK BMS and the active balancer in that BMS top balanced all 4 pairs of cells with 560Ah total capacity to perfect 3.65v in one charge. Huge difference between +2A active and .15A max (and usually much less) passive balancing.Seems like you are on track for success. The active balancing on a JBD is super slow, so it will take days and weeks of eeking it along like that.
Frustrating, too, when hitting the 3.65 cutoff voltage.
I had the same issue, but have access to the cells, so just attached a capacitive active balancer and it was done plenty fast.
Hey - I think I figured out a way to automate this top balancing process using only the built in balancing.
I had thought about doing the same and am sure that it will do the same balancing that I have done but I am just paranoid about requiring the BMS to shut down charging. I like it there but do not want to rely on it being there. Like a safety pressure relief valve that you never want to trip.Hey - I think I figured out a way to automate this top balancing process using only the built in balancing.
First, make sure you are set to only balance when not charging.
Then, under Parameter View, top two values:
- set the overvoltage to 3.55v
- set the overvoltage release to 3.45v
The BMS will charge up until whatever cell hits 3.55v, then charging will be turned off and active balancing kicks in.
The balancing will continue until the voltage in the highest cell drops to 3.45v, then the process starts again.
You will need to choose your two values (above) to fit your particular needs. the 3.55 / 3.45v seems to be working for me.
Then increase the values up to as high as 3.65 / 3.50v. Personally, I'll stop at 3.55 / 3.45 or maybe 3.60 / 3.45, but no higher, as it's not really necessary.
I'm just testing this now so I'll update if things don't go well.
I top balanced this 4s 160ah pack about 6 months ago and so far it's still plenty close enough, so this is just fine tuning it.
Yea, I cringed when I saw pretzel using his BMS (last ditch battery safety device) as a charge controller.I had thought about doing the same and am sure that it will do the same balancing that I have done but I am just paranoid about requiring the BMS to shut down charging.
Thanks for checking my work and watching out for well beingYea, I cringed when I saw pretzel using his BMS (last ditch battery safety device) as a charge controller.
The charge controller is called a charge controller because its specifically designed to control charging. The BMS is not. Pretzel, you should start a thread with what you are proposing and lets get to the root of your charging woes and fix it the right way.
With 14.2v charge and the parameters that you describe I can concede that you still have redundant protection as long as your imbalance is not too great. With my pack,I could not charge to 13.9v without tripping my OVP at 3.65v. Like I said, I started with 300-mv imbalance. At that level, I lowered my float voltage to 13.9 and watched it as the voltages came up and turned off charging when cell #3 went above 3.64vAww, thanks for checking my work and watching out for well being
No charging or balancing woes here.
Yep, my power supply is an Iota DLS-30.
With the plug in it tops out at 14.2v, so that's still just 3.55v/cell, which I'm calling 100%
I initially top balanced it 6 months ago with a bench supply + a Heltec type active capacitive balancer.
Just checking it's still solid at the top, and indeed it's within about 0.035v/cell
So this thread is still JBD related - ideas on how to use it to top balance through settings using the built in functionality
I stated the process in my above post, but if anything seems unclear or off, please ask away, -thanks
