Has anyone ordered the JBD-SP10S020 in a 6S configuration per chance?
This BMS can be ordered 6S-10S and I've ordered it in 8S and been able to change it to 10S by unsoldering the solder joins on the balance leads and then specifying the new cell count in the app.
I'm now trying to use one of these BMS's in a 6S config but I can't seem to work out which balance leads need to be joined and I know I'm treading on a very fine line with a high possibility of making a mistake and blowing the BMS.
Has anyone got one of these and may be able to see which ones are joined?
The pic below is from the underside of the balance lead plug in 8S config (you can see the soldered pins without needing to take off the aluminium plates if anyone could look for me)
Thanks
Thanks
