Suijkerbuijk
I cannot be held responsible for this information.
I see what happens
The bms calculation is wrong .
I see that happens if a cell is not correct.
The total volts is correct but your ampère are not.
So the bms think its that .
Same problem here
So it means new top balance the cells again for you go parallel again.
Or switch one bms its charger off.
So only one Battery is charge
No battery is the same so you always have some change .
But than again you use mix battery Ah and that ask that it go wrong .
The moment one battery hit the max volt the charge will stop and will not charge the other battery.
Soon or later that battery will go out of balance.
Reason in all Manuel it tell use the same battery in parallel with the same brand and same Ah.
Same problem here
