TLDR: 48v li-ion NMC battery modules, why does JBD 3.7v bms 7s-20s descirption say that it is not good to parallel them, if I don't expect balancing currents higher than BMS can handle, protected with a fuse for each 48v module?
Long version:
Hi all, I have 2 times a 14s 10kWh block, it is NMC chemistry (so 3.7v nominal) They are rated 202Ah each.
I have one load which can pull up to 250A, peak power output. So that it is 0.625C for the whole pack, which is fine.
Now I would like to put a JBD BMS 200a or 300a on each battery module, as well as a 250A fuse for each block. I could add another 250A or 300A fuse where the positive lines come together, so that both modules will not deliver 500A in case of a short.
But the JBD BMS says in the description not to put them in parallel. This will have to do with high currents when one of them disconnects or reconnects (for example the temperature was too high and became lower again)
I realize there are better alternatives with CAN bus communicating slave modules and a master. However, it is much more cost effictive to put in two JBD BMSs.
The system is made as such it should never reach the limits of the battery modules.
However, it could still happen. If it does, a fuse of 250A could go out if the balancing current between the modules can be that high for a few seconds.
Next to the 250A fuse I could put like 150A DC breakers for easy resetting, but I don't really like them as they can burn out or burn fixed shut.
If I see youtube videos of what Will Prowse and others are building, they are often paralleling large amounts of 48v batteries, although typically LiFePo4, but the basic problem is the same.
Since this is an electric boat with NMC chemistry, things may be a bit different. If one module fails (bms disconnects) you still could reach the harbor on the remaining active battery module.
Thanks in advance.
Long version:
Thanks in advance.
