pi@hassbian:~ $ jbdtool -t ip:192.168.15.35,23 -d 3 -a
main(801): transport: 0x7e99b7cc, target: 0x7e99b7cf
main(826): transport: ip
mybmm_load_module(51): NOT found.
mybmm_load_module(72): init: 0x246f8
mybmm_load_module(79): adding module: ip
main(829): tp: 0x3c584
mybmm_load_module(45): mp->name: ip, mp->type: 2
mybmm_load_module(72): init: 0x19a84
mybmm_load_module(79): adding module: jbd
main(832): cp: 0x3c510
jbd_new(415): transport: ip
jbd_new(424): pp->target: 192.168.15.35, pp->opts: 23
ip_new(69): target: 192.168.15.35
main(844): charge: -1, discharge: -1
main(868): mqtt: (nil)
main(914): outfp: 0x1e8f820
jbd_open(435): opening...
ip_open(97): s->sock: 0xffffffff
ip_open(100): creating socket...
ip_open(119): temp: 192.168.15.35
ip_open(126): connecting...
jbd_get_info(263): transport: ip
ip_write(196): s->sock: 0x3
ip_write(201): bytes: 7
ip_read(179): debug: 3
jbd_verify(49): len: 34
jbd_verify(84): good data!
jbd_std_get_info(172): voltage: 39.13
jbd_std_get_info(173): current: -4.41
jbd_std_get_info(174): capacity: 54.13
jbd_std_get_info(179): fullcap: 130.00
jbd_std_get_info(180): cycles: 12
jbd_std_get_info(181): pctcap: 2a
jbd_std_get_info(196): balance: 0000000000000000
jbd_std_get_info(212): protect: 0000000000000000
jbd_std_get_info(221): year: 2021, mon: 3, day: 16
jbd_std_get_info(224): fetstate: 3
jbd_std_get_info(225): mfgdate: 20210316
jbd_std_get_info(226): version: 2.2
jbd_std_get_info(230): strings: 10
jbd_std_get_info(231): probes: 2
jbd_std_get_info(236): temp[0]: 2851
jbd_std_get_info(236): temp[1]: 2846
jbd_std_get_info(242): temp 0: 32.216
jbd_std_get_info(242): temp 1: 32.207
jbd_verify(49): len: 27
jbd_verify(49): len: 33
jbd_get_info(271): r: 0
jbd_get_info(280): cell 0: 3.914
jbd_get_info(280): cell 1: 3.912
jbd_get_info(280): cell 2: 3.914
jbd_get_info(280): cell 3: 3.913
jbd_get_info(280): cell 4: 3.912
jbd_get_info(280): cell 5: 3.915
jbd_get_info(280): cell 6: 3.913
jbd_get_info(280): cell 7: 3.916
jbd_get_info(280): cell 8: 3.913
jbd_get_info(280): cell 9: 3.915
jbd_get_info(288): cells: total: 39.137, min: 3.912, max: 3.916, diff: 0.004, avg: 3.914
dfloat(231): dint: label: Voltage, val: 39.130001
dfloat(243): temp: %-25s %.3f
Voltage 39.130
dfloat(231): dint: label: Current, val: -4.410000
Current -4.410
dfloat(231): dint: label: DesignCapacity, val: 130.000000
DesignCapacity 130.000
dfloat(231): dint: label: RemainingCapacity, val: 54.130001
RemainingCapacity 54.130
dint(188): label: PercentCapacity, val: 42
dint(200): temp: %-25s %d
PercentCapacity 42
dint(188): label: CycleCount, val: 12
CycleCount 12
dint(188): label: Probes, val: 2
Probes 2
dint(188): label: Strings, val: 10
Strings 10
dstr(253): dint: label: Temps, val: 12.0,11.5
dstr(265): temp: %-25s %s
Temps 12.0,11.5
dstr(253): dint: label: Cells, val: 3.914,3.912,3.914,3.913,3.912,3.915,3.913,3.916,3.913,3.915
Cells 3.914,3.912,3.914,3.913,3.912,3.915,3.913,3.916,3.913,3.915
dfloat(231): dint: label: CellTotal, val: 39.137001
CellTotal 39.137
dfloat(231): dint: label: CellMin, val: 3.912000
CellMin 3.912
dfloat(231): dint: label: CellMax, val: 3.916000
CellMax 3.916
dfloat(231): dint: label: CellDiff, val: 0.004000
CellDiff 0.004
dfloat(231): dint: label: CellAvg, val: 3.913700
CellAvg 3.914
dstr(253): dint: label: DeviceName, val: 15300034-SP10S009-P10S-60A
DeviceName 15300034-SP10S009-P10S-60A
dstr(253): dint: label: ManufactureDate, val: 20210316
ManufactureDate 20210316
dfloat(231): dint: label: Version, val: 2.200000
dfloat(243): temp: %-25s %.1f
Version 2.2
dstr(253): dint: label: FET, val: Charge,Discharge
FET Charge,Discharge
