Hi I've been using one of the JBD 100 a smart 15s BMS that I purchased from battery hookup. I was using the bms as a 14s configuration and it has always worked very well. But now I am wanting to uses this 15s bms as a 12s bms and I cant find any information on how to change this from the 14s that is set up for now to a 12s setup. Can any of you tell me what I need to do to be able to use it as a 12s. how does it need to be wired and do I need to soldier any pins on the back side of the bms thanks for any help you can give me on this.
