jbd / overkill bms - state of charge
Since I only charge to 3.41 volts the current accounting never resets.
It drifts lower by ~1.5ah per charge cycle.
Not a problem because I have an hall effect sensor based battery monitor which is accurate enough for my application.
squowse
Id be happy enough if it reset at the top or bottom. It's just resetting itself in the middle. I'm going to leave it alone and see what it does. When the parameters are changed it resets and uses voltage estimation.
Have you manually reset it at the top?
MrM1
I'm Here, But I'm Not All There
N. Central FL
Yeah I like some of the features of the IOS version. Like you can calibrate the cell voltages to a meter, you can not do this with the Android app, but not sure if can do the reset of the amp hour / % of charge or not. Im going to take mine home here in a few and check it out
curiouscarbon
Science Penguin
anecdotally, the JBD 120A 4S BMS i use only seems to report 0.0A or 0.5A but rarely anything in between.
this quantization error surely causes some amount of the drift in coulomb counting mode.
MrM1
N. Central FL
Unless the "reset" button in the middle of the page does it, it looks like you'll need the pro version of the ios app
MrM1
N. Central FL
Just got them pro version. I am definitely not as good impressed with the ios version
MrM1
N. Central FL
The android version has this setting that resets the battery percent used to what ever the amp hour used is based on your capacity.
It's handy to sync the capacity when the amp hours are full.
Isaac-1
This all leads to the question of what is the proper way to do a charge cycle on these batteries to get them to switch to method 2?
squowse
Did you read the pdf? It seems to be saying that a complete charge, complete discharge followed by a complete charge should do it.
I still struggling 🤣
drbytes
So what was it in the end? I'm facing similar problems, I cannot rely on the SOC.
Perhaps it's because the battery pack is still new, it only has had 4 cycles and from what I read it will start ie at 310ah but eventually settled to what's on the tin, in my case this is 304ah.
I've set it to 310 in the beginning and after the fourth cycle I've set it to 304. Immediatly the SOC shot up from 8% to 14%. So I set a lower capacity and then the bms decides it now has an extra 6% soc? Baffling.
Bob B
Photon Sorcerer
Anytime you change a parameter the BMS reverts to a guestimate for SOC based on voltage ..... Once you go thru a full charge cycle after that it will start tracking based on current in and current out again.
squowse
Yes I haven't had a problem for a while. I made sure not to touch any parameters. As best as i can tell from the slightly broken English of the manual it needs to be discharged from 100% to 0% then all the way back up to 100% to initialise. I think the charging might need to be uninterrupted as well.
squowse
I had much bigger jumps than that
drbytes
Thx for the info, I'm in the midst of cycling it now, hope it'll rectify itself as I have quite a bit of Nodered logic tied to the SOC to switch output source to battery/utility and initiate charging etc
Bob B
Photon Sorcerer
In my experience, the SOC would reset if I reached 100% ..... it didn't require a full charge and discharge cycle .... there are several different version of this BMS, so your mileage may vary.
