JBD Smart BMS UART Connector Type
alferz
Probably a long shot, but wondering if anyone has been able to identify the connector in the photos. This is the 4-pin Bluetooth module cable that connects into the UART port on my JBD 8s 100a smart BMS (SP16S020). I want to make some longer cables because my batteries are in a steel cage which effectively blocks Bluetooth signals and to route the BT module out of it, the included 8" cable is too short. Looked long and hard for these but no dice yet. They are 2.00mm pitch.
May be, JST XHP4, or Molex 502351 0200 for the housing, pins extra.
Mike
Thank you @mikefitz I found both of those but they weren't quite the same. Luckily, I realized I had overlooked something in the manual. Under each of the ports in the tag column there is a note "HY2.0-2P" and 4P for the UART connector. These are the part numbers for this particular connector, and luckily they are readily available on AliExpress. Hope this helps someone looking for these connectors!
So I purchased a couple of jbd bms, only one arrived and it was missing the art cable. After no luck with the seller, or my search, I posted here. Some one on the forum sent me a link to your post. That is exactly what I need. I ordered from Allieexpress. Hopefully they get it right.thanks man
Hi. Have someone schematics of uart cable (pinout).
I need to know which is plus, gnd, tx and RX.
I have JBD SP17S005.
Thanks
