Hey all, well i finally figured out how to get my app working after reading posts here... after getting frustrated about the fact you need location turned on with android and finding out it's an android thing not a xiaoxiang thing i went ahead and did it. So got it working on my new bank of 16 cells. However, other than when i change parameters i need to do it multiple times for them to be actually changed, and finding out that it won't actually change the 20s to a 16s, i've found that the JBD BMS senses the voltages completely up the shitter. I test all cell voltages at 3.29V or 3.3V (very tight range of 0.01V) with a multimeter, whereas the BMS is saying there's a range of about 2.9V to 3.42V (about 0.52V range).
specs of setup:
16s x Winston 200Ah cells
BMS - JBD-AP20S006-L20S-300A
App - Xiaoxiang3.1.1026
At this stage i'm not really all that impressed with the whole BMS/App system and don't really want to trust thousands of dollars worth of battery bank to such a dodgy BMS setup (if i've got everything working correctly!) but am open to hearing any suggestions on something i'm doing wrong if anyones got any input? I've checked all the wiring and it's hooked up correctly...
TIA
specs of setup:
TIA
