I've got 2 early model (purchased in May) JK 4S BMS (JK-B2A8S20P) which are both creating electrical noise / interference only when charging.
I first noticed this with erratic current readings on my Victron BMV-712 Shunt which only occurred while charging and initially thought it was a faulty shunt, but bypassing the BMS fixes the issue.
The problem only occurs while charging through the BMS and it causes the BMV-712 current reading to fluctuate with current readings from -20a to +20-30 amps all while charging with a constant 50a. I can also hear coil whine or similar coming from the BMS when this happens. I have replaced all the BMS cables and this happens on both my JK 4S BMS's.
When discharging through the BMS there are no issues at all and it works perfectly. I also have a modified PSU which I use as a charger and when connected through these BMSs the current output jumps all over the place, whereas when connected to other battery banks with JBD BMS the charger output to rock stable.
Anyone else having similar issues while charing with the new 4S JK BMS?
@Nami - was there an issue with the charging circuit mosfets on the early model JK-B2A8S20P units?
