Nami
- Jan 13, 2022
- 153
There is a big lost using the boost converter?This looks great. I just built two 460Ah/4S packs using the JK 8S/200A BMS with a 12v-24v boost converter. I'd love to be able to eliminate the boost converter, and run 4S directly.
No, there isn't much loss, but eliminating the external boost converter makes things a little simpler.There is a big lost using the boost converter?
same sizeI was just talking with the HankzorBMS Store on Aliexpress because the 8S version was not available anymore and they told me they have a new version 4s-8s coming in May. They say it will replace the JK-B2A8S20P and have the same model number.
@Nami any other differences? Same package dimensions and only internal circuits differ to handle fewer cells?
@Nami was I talking to you on the HankzorBMS Store message center or is there someone else from your team?
I was ready to order one for my 8S configuration, but I guess I'll wait to see this one and check out Andy's review. I would gladly appreciate a free BMS by the way. It will probably feature in a YouTube video series I'll make when I get to build the track camper, but that won't be ready until the end of the year.
What is the heat function for? Heating of the cells in case of low temperature? Has that a heating pad included or just a switch to turn on one based on temperature?same size
add one interface support heat function
turn on heating pad based on temperature。What is the heat function for? Heating of the cells in case of low temperature? Has that a heating pad included or just a switch to turn on one based on temperature?
While we would all love a free quality BMS, I think the best bang for your buck would be to send them out to a YouTube presence for review.This is a sample,
which will be sent to the off grid garage test soon.
It supports heating and 4S 5S 6S 7S 8s,
support 200A discharge/charge current
with active balance 1A/2A
support RS485...
will be soon................
Nami: Although it is approaching summer in USA, I can definitely test the new heater function. (I live in 'foothills' of the Sierra Nevada mountain range, where evenings still get quire cold.) I already have 2 heater pads to use with my newest "4S" battery build, and was about to buy and program a separate thermostat. Your new feature makes that unnecessary.This is a sample,
support RS485...
EMMMWhile we would all love a free quality BMS, I think the best bang for your buck would be to send them out to a YouTube presence for review.
This is Will Prowse’s forum, so his is a great channel to sport them.
I do review the products I order sometimes, but I am a contractor with a hectic schedule, so I’m slow on the reviews…
What heating options do you recommend with the BMS? Do you have a list of heaters that mate well with this?
I live in Charlotte, NC and it gets below freezing here for 3-4 months of the year, but certainly there are colder areas from mine. A 200A BMS would support the 300Ah cells better in a rv build.
I am looking forward to the results of this gem.
