packrat1969
- Nov 30, 2021
- 29
Hello,
Is there someone out there that can help me clarify a couple of issues regarding the JK-B2A8S20 series of BMS'? It seems that not a single vendor on Alibaba or AliExpress can reliably list the specific model number with it's included feature set for this line of BMS'. The manufacturer doesn't even have a printed English manual specific to this BMS listing each variant but only mentions them in passing. I found Steve_S' revised version, but it only had the same vague chart. All in all, this makes it rather confusing to determine just what version is being offered when ordering. I also don't see a generic UART version, so I suspect I'll need to order one of the RS-485 versions along with the appropriate RS-485-to-USB adapters. Below is an incomplete listing of what I suspect are the model's variants, so feel free to correct any inaccuracies or misunderstandings I have:
JK-BMS-B2A8S20P (Bluetooth, RS-485)
JK-BMS-B2A8S20P-H ((Bluetooth, RS-485, Heating Relay Port) I have yet to see this model explicitly listed.
JK-BMS-B2A8S20C ((Bluetooth, CAN Interface)
JK-BMS-B2A8S20C-H ((Bluetooth, CAN Interface, Heating Relay Port)
I am currently using a JBD-SP04S028A 150A BMS, but it has some communications and balancing current limitations I'd like to forego by replacing it with the JK unit. First off, it has only one RS-485 port that can be used with EITHER an external Bluetooth module OR an external UART-to-USB adapter box. They both work great, however the both use the same 4-pin port. The UART-to-USB arrangement seems to work well with all my Victron hardware (Cerbo, MPPT, & Shunt) using Louis Van Der Walt's dbus-serialbattery driver, but this means that every time I want to tweak the BMS settings, I need to disconnect the USB communication path in favor of the Bluetooth one I can use with my phone. I'm probably not the only one who hates the PC software. Currently I have a multi-pole switch that can do this properly, but what I really want is the option to connect to the BMS with Bluetooth and UART/RS-485 simultaneously. From what information I've witnessed so far, it seems that models in this series of JK BMS' have Bluetooth built into the main board, eliminating the need for an external UART-fed Bluetooth module. Can someone confirm this?
Additionally, the JBD unit only balances with something like 70mA (??), and cannot keep up with the runners in my Basen "Grade A" 280Ah 4S pack at the end of a charge cycle. I wonder if 2A of balancing current stripped from the misbehaving cells and sent to their brethren might do the trick.
Now, as far as connecting this BMS to something like a Cerbo GX, the unit's documentation appears to be seriously lacking. I see there is a port on the BMS labeled RS-485, but will it communicate properly with one of these?
It does not appear to come with a harness ending in the proper connector to plug into the RS-485 port. This I can remedy if necessary. Below is a link to one on AliExpress: RS-485 to USB
https://www.aliexpress.us/item/3256...vfUNAJxZ&utparam-url=scene:search|query_from:
I have also seen one of these being sold with/for these BMS'. It looks like some kind of external RS-485 conversion dongle, that has a (3-conductor???) connector that plugs into something on the BMS while the wires exiting the other end terminate in (2) bare conductors. I thought RS-485 was already generated onboard the BMS, and I would just need to to convert its serial protocol to USB. What is the purpose of this item? RS-485-to-CAN?
Here's a link to one:
Any relevant directions/comments appreciated.
packrat
packrat
