RCinFLA
Solar Wizard
- Jun 21, 2020
- 4,119
Not sure what you are trying to accomplish by heating center MOSFET's with a soldering pencil.This is a pretty flawed test, but it does have some merit. I coated the mosfet base and thermistor with whiteout and set my emissivity to .95. I scrapped the whiteout off a little bit where soldering iron made contact with the mosfet base. I left the soldering iron on for a while, then removed and took some pics with the thermal camera.
In the thermal camera view you can see about a 4 deg F difference between the thermistor location (white pointer) and mosfet base (red pointer).
There is a lot of copper here (heavy trace, high current jumpers, etc). I think it helps to give the thermistor a fighting chance of getting a somewhat representative reading. Obviously this 4 deg F difference will change with higher temps, but still gives us an idea.
I believe the default MOS overtemp setting on the JK BMS is 100C. Does it seem realistic that the mosfet base temp would be within an acceptable range at this setting?
View attachment 308210View attachment 308211View attachment 308212View attachment 308213View attachment 308214
More insight will be obtained by having variable current pass through BMS and having a multi-channel thermocouple meter with small thermocouples attached to metal tabs of MOSFET's, at least on two ends and middle MOSFET's will give their temps vs BMS current. I would not expect the temps at various MOSFET positions to be the same for several reasons.
Although fairly good, the thermal resistance between MOSFET die and its package metal pedestal is not zero and the die will be several degrees C hotter than package pedestal.
When I did this a couple of years ago, I got this result.
