Ross DOC
- Nov 22, 2022
- 5
When I active the discharge on the bms connected to a voltronic pip max 8kw start the short circuit protection and the bms remain inactive, Seem a problem of the inverter , turning off the circuit breaker on positive pole of the battery the bms active correctly the discharge mode , any suggestion of inverter parameter? Obviously I checked thousands time all the wiring and all should be ok
