Jk bms cable came away from connector
ddonq1412
What is the best way to repair a cable that has broke off from the connector balance lead number 2.
If its the standard JK BMS with the JST XH connector. The contacts are P/N SHX-001T-P0.6 for 22 to 28 Ga wire.
The contact slips in from the back of the connector and there is spring tab that pops up into a recess to keep it from coming out. The tab can be released and the contact removed. Crimp a new contact on the wire and push the contact into the XH connector.
I haven't seen the new JK Smart BMS up close but from pics it looks like they changed the connector for the cell voltage/balance wires so the above probably does not apply.
