I have one of the JK BMS Inverter units and I'm having trouble getting it to communicate with the PowMr POW-SunSmart SP5K Inverter. I have the RS485 connected to Port 1 on the inverter and the RS485 on the BMS Board.
The inverter is configured with the WOW protocol, which is for SNRE units, and the BMS is has the following:
UART1: 9
UART2: 1
CAN Prot: 0
I've tried changing the a few of these around, but when I turn the Inverter to use the BMS (from disabled), the BMS will start rebooting and loop until I turn off that setting in the Inverter.
Any ideas what settings I need to configure here? Considering there are 3 options with >8 settings each, there's a lot of permutations I don't want to try if I don't need to.
thanks, Kori
UART1: 9
UART2: 1
CAN Prot: 0
thanks, Kori
