So have have built up two of four DIY boxes using 314ah cells with JKBMS V19 (19.09) and am now stepping into the wonderous world of BMS setup.
I have used the app to set the batteries to LiFePo4 and then used Off-Grid Garages JK Inverter BMS (JK-PBxx Series) setup initially for the BMS settings that you can find on his website.
off-grid-garage.com
I have connected a Chargeverter (120v supply) directly to the isolated battery and started the charge.
I measured the voltage at the pack outputs and set the calibrated voltage to that value.
The Chargeverter shows 10.1amp, my Klein clamp meter shows 12.5amp on the cable.
I set the calibrated current to 12.5.
Everything seems fine as charge starts. Charged overnight, and in morning cell voltages seem fine and climbing as it continued charging.
Checked several more times, and then got busy with other stuff.
Went out and checked cell voltages and they were up in the 3.71v range!? I immediately stopped the charge to figure out what is going on.
So I am confused. Why did it go over the OVP setting of 3.65? Is that not Over Voltage Protection? I assumed that the charge would drop off as the batteries reached that BMS setting. Now I am questioning life, battery life. Newb Help Needed!
My Settings
I share here the settings of all devices I have configured for LiFePO4 batteries. As a beginner, it is very confusing to understand all these different options solar charge controllers, BMS, shunts…
off-grid-garage.com
