RV10flyer
Solar Wizard
- Mar 8, 2021
- 1,198
You are correct. Thank you.My pushbutton turns the JK on and off. You need to hold the button in for 5-seconds or so.
Ok that's certainly less than 65mA that was mentioned earlier but that is still around 8Ah per month. I'll order a couple to test. @RV10flyer Do you use the RS485 port?Everyone of my JK's consume from 10 to 14 mA. The LCD consumes 32 mA. they are no different than my other seven brands of PMS is that I have used. It's really not that much power. Less than 1W.
That button and the ability to turn it on and off at will is rather handy. Except for that time when I turned off and never turned back on.You are correct. Thank you.
Yes i had the same Problem with shutting off the screen. I just disconnected the GPS plug, but toggle switch will be the way to go! would be nice if they already deliver it with a switch. or if they update the firmware do double tab the screen to turn it on and off. should be no problem?I have 10 various bms's. All between 0.003-0.040A at 53.3V. My JK 150A with 2A balance consumes between 0.005-0.010A. My JBD with the contactor consumes 0.040A. Overkill= 0.017A. Ant= 0.003A. QUCC= 0.019A. Daly= 0.015A.
Edit: My 6 new JK200A 8S-20S (Wired as 16S) BMS's consume 14mA and the LCD consumes 29mA. All you need is a toggle switch on the red wire from gps connector to turn off LCD.
Hi!You really don't need a big heater if you put your cells in an proper insulated box. I use 7W polyimide heater on mine (not with the heater output on the BMS because mine don't have it but with a simple electronic thermostat) which keeps the batteries warm even in the worst conditions.
This depends if the BMS draws power from the most positive cell (B+) or if it uses power from cell 2 or 3 as some BMS do.Is it sufficient to measure the current in the B+ wire to the BMS?
I have the later BMS and the small 2.5" display. Does the larger display have any audible alarms? It would be great to have an audible alarm to tell me if the BMS is about to shut down the battery. On a boat this is very important as the battery runs navigation lights, chart plotter, radar, etcI see that your BMS is an earlier version. After January 2022, we agreed to replace all BMS interfaces with those in the picture,
I will contact the engineer to arrange a link cable of the previous interface for you,
I had the same question regarding “charg. plugged”… I contacted the manufacturer/seller on AliExpress and they informed me it is the indicating whether a heating pad is connected or not. So the indication is rather misleading.With the Softwareversion (V11.17H) seems to be some new information available on the main page. I think I understand "Heat Current" and "Heating Status" but what does "Charg. Plugged" mean?
first I thougt it will detect if I am Charging the Battery (Daly and Jiabada do) but as you can see from the screenshot, I am charging at the moment with around 200W but "Charg. Plugged" still says: "Not Plugged"
@Nami perhaps you can tell?
I've got decades of power electronics experience, including power inverters, battery chargers, and BMS's. Let me know if you or anyone want to collaborate on an open source BMS. I've reviewed what is currently available on-line and github, and JK is years ahead. But it's not perfect and it's not open.It seems like there is a real need for an open source scalable BMS for the DIY community. Sourcing reasonably priced copper inlay PCBs for the MOSFET power path would be an issue that would need to be resolved for that to happen.
Sounds really good and i would be interested. I could probably not contribute really much, but maybe some ideas. I have some basic knowledge in electronics including simple circuits with transistors, mosfets and build some easy power supplies. I even modded some heavy server power supplies to have adjustable voltage output to some extend. My biggest is a beefy 6 kW server psu that delivers 36...52V DC at more than 100 Amps. Couldn't get it to run from lower voltage as the UVP is very resistive.I've got decades of power electronics experience, including power inverters, battery chargers, and BMS's. Let me know if you or anyone want to collaborate on an open source BMS. I've reviewed what is currently available on-line and github, and JK is years ahead. But it's not perfect and it's not open.
Tim
