MWeiss
- Apr 22, 2020
- 73
I've had my battery bank running three 16S 280Ah groups of cells with three JK BMS running in parallel to a common set of buss bars for about 6 weeks now with no issues once I ran the batteries through a full discharge cycle. It was always accurate after that.. until this morning. The batteries got down to 20% overnight and sometime this morning, the second BMS reset it's "full" state to 100% when the battery was really below 50% charge.
Since everything is paralleled, the load never causes more than 2-3% difference between battery banks.
Is it common to have a BMS lose calibration like this? Note the Ave Cell Volt readings. I've turned off charging on the 99% one at the time of this capture until I figured out it wasn't REALLY 99%.
The only event that I suspect may have caused the glitch was that charge current went over 100A for a short bit as we had some diffracting clouds boost my solar arrays output by 130% of normal for a few minutes and the BMS hit the charge current limit and shut down charging until I set the charge current to a higher value. Possibly that condition caused a glitch, but would like to know if others have encountered this loss of calibration on this BMS before. These are 200A BMS units.
