philos70
- Dec 25, 2022
- 36
This. Good eye and research @GXMnow! I also had mine reversed even when using the regular JK Inverter BMS harness wires but caught it before I connected anything.I think you may have the red and black harnesses flipped.
I haven't gotten that far. Once the BMS works I'll deal with that.The only thing I can think of is that somewhere in the C9- or C9+ wires something is goofy. You changed out the BMS so that pretty much rules out the BMS. I would swap out the cables from the old BMS to the cables from the new BMS. If that still doesn't work then change out the rail.
Is it possible that cell #9 has been turned off in the BMS parameters? Once again, you swapped BMS so I doubt you accidentally disabled cell #9 in both of them.
Off topic but your the end of your NTC lead should be on the top of the cell, not sitting in the gap between the cells columns.
the harnesses were reversed - TOTAL USER ERROR. I love learning, and making a fool of myself in public...I found a PDF manual for the JK inverter BMS
Page 17 shows the connections. It looks to me like the BMS in your picture is turned around the other way. I can see B12 between the two connectors with black wires. Your group of red wires shows C12+ on the upper PC board. That's not good. I think you may have the red and black harnesses flipped. The huge voltage difference across those may have done some damage.
At the BMS board, the 3rd pin from the right should be the pack negative, Cell 1- but following the wires in your pictures, it is going to cell 9-. That is applying over 25 volts to the 0 volt point on the board. I would not be surprised if it has burned a lead off the PC board.
It's all working. My tail is all aquiver!!! Thanks for all the help... This forum is great!!Is it all working now? Or did it damage anything?
Glad to hear it. The JK-BMS is a well designed piece. I am using one of their older black ones, been working for almost 5 years now. Only issue I had was a balance lead failed. It showed 2 cell as zero volts. Fixed the lead and it has been perfect again.It's all working. My tail is all aquiver!!! Thanks for all the help... This forum is great!!
