onrbikes
Have posted previously but no answers, so have included a couple pics.
I tried and failed to swap my Daly BMS to my new JK
JK B2A8S20P
Once I installed and turned on the new JK bms, the settings and numbers all showed good via Bluetooth app
Showed my cells were well balanced with identical resistance.
Turned on my Victron with shunt and after 10 seconds the Easysolar would trip going into a low voltage alarm. It stated 2volts even though the batteries were well over 27volt.
All the connections were good. After a few attempts checking with my multimeter found when the victron was reactivated
the voltage at battery+ to P- would drop from 27.5V to low volts, thus the victron shut down.
I did try to change a few things on the bms but because I'm offgrid had to reinstall the Daly.
Any thoughts for next time I try it to instal the JK?
Thanks
JK B2A8S20P
Thanks
