Have a 48V 16S1P setup with a JK BMS and have a couple questions-
Everything is connected correctly and the BMS turns on and shows voltage. The voltages in the app are different than the voltages on my multimeter - will this improve with time (charge/discharge cycles) or is there some calibration I should do?
When the BMS is connected, should I be registering the same voltage at P- as I do at the negative terminal of the cell (52.8) when the BMS is on? Charge and Discharge are both in the "on" state
