Hi all I have a Sumry 3.8kw 24v hybrid inverter from AliExpress, it looks similar to EASUN. It suppose rs485 BMS communication (not just for pc) using pylon or pace protocols, via a rj45 connector.
I'm having trouble wiring up my JK BMS I have the Pb series with interface board, rj45 plug in port 1 (closest port to LEDs).
I have tried wiring it as per my inverters pins as I understand you only need 3 pins, RS485A, RS485B and GND.
What is confusing me massively is JK BMS manual where it says pins 1,8 and 2, 7 for the coms... Then I read that JK do the pin numbers opposite to the standard way of reading them
Please can someone help explain which orientation the pin numbers run ref to the JK manual and why it says 4 pins when I only need an A and a B connection for rs485... Which pins do I need? A diagram with circles would be brilliant
Thanks. I have attached my inverter manual page.
