The info I linked to is correct:
diysolarforum.com
They call it RS485 because the RS485 adapter plugs in there (the 4 pin socket), but the signal at that port is UART/TTL, and can therefor be connected to a UART/TTL to USB converter. I have this also mentioned on my Github, and have Python code there to talk to the BMS:
github.com
The CAN bus (3 pin socket) is only present if this is explicitly enabled, which it is not by default (at least not last time I checked).
Hankzor JK BMS with screen and power button
silicone wire Thanks. I was hoping there was someplace in North America that had it stocked already.
GitHub - PurpleAlien/jk-bms_grafana: Read data from a JK BMS and graph it in Grafana
Read data from a JK BMS and graph it in Grafana. Contribute to PurpleAlien/jk-bms_grafana development by creating an account on GitHub.
