ShockinglyAverage
- Nov 10, 2020
- 46
I’ve had this BMS running for over a year. Last year I put the van in storage and eventually the voltage got low enough that the BMS shut itself off. When I got the van I charged the battery enough to be able to turn the BMS back on. Everything went back to normal. Well a couple nights ago it got below freezing so the under temp protection kicked in. Later in the day, after the temp rose above the recovery setting it still wouldn’t turn back on. I went into the settings and noticed everything is now at really weird values. No matter what I change, everything reverts back to these (pics) values after closing and reopening the app. And some things when I try to change I get the “sensing failure” message. I know some thing can’t be changed before other (I.e. trying to set the ovp before setting the recovery) so it’s not that. Any idea what’s going on? I’ve searched all over and I can’t find any threads that match this.
Hitting the preset tabs for the 3 different battery chemistry at the top doesn’t change anything.
This is the old style JK not the newer inverter ones.
