MountainmanBill
- Feb 20, 2021
- 134
JK BMS 2A 200AMP managing 16s 48-volt battery bank.
The Victron BM SOC says 93% and the JK says 100%. They are never in agreement.
The two Morningstar Tristar 45-amp 150-volt Charge Controllers are set at: 56-volts Absorb and 54.8-volts Float.
All is well until the battery nears full SOC. Then the BMS turns off and on the charging every few seconds, for about ten minutes. Then it turns off the charging until it feels like turning it on again. That on-again off-again can't be good for anything.
Even when it's off, the BM is showing wild fluctuations in the battery voltage.
This doesn't seem like this would be a normal operation.
What also puzzles me is that a fully charged battery is 58.4 volts (3.65x16). The BMS shows a voltage of 55.68 volts and says the battery is fully charged. How is that correct? How about some guidance here? Thank you very kindly...
