Those bms default settings are the best I’ve seen, they must be learning. They are a good starting point. I’d probably lower the bulk in the inverter to 55.6 then you can just leave the start balance alone in the bms. Then just play with the current till it’s balanced. If the inverter decides it’s done with bulk/absorb early, you can temporarily raise the float voltage to just under the bulk(55.5) to keep it there till it’s done balancing. When done don’t forget to set your float back to 54.
