Hello all,
I have a 200A JK inverter BMS JK-PB2A16S-20P mounted in a EEL battery box connected to a Deye 6kw inverter. The system is mounted in a remote location and a I do not have access to it at the time. As many have complained, the SOC estimation of this BMS is quite bad especially when the battery drain is low and there is no sun to recharge the batteries and reset the SOC to 100%. I for one observed an almost 60% error in one instance when there was no sun for several weeks to recharge the batteries. In my case the inverter constantly draws around 15W/h from the battery. This consumption is measured by the inverter but the bms sees no consumption and in consequence does not change the SOC value. In this particular case the battery SOC was constantly 60% for almost 3 weeks but the voltage of the battery gradually went down until it reached the 0% voltage threshold and then it reset to 0%.
Has anyone been able to determine what is the current and voltage sampling OPAmp / IC that JK uses to measure the current across the shunt resistors in this BMS? I know that the shunt resistance is 50 micro ohm for the 200A version and that would make it extremely difficult to measure low (under 0.1A) currents accurately (the voltage drop across the shunt would be only 5 micro volts at 0.1A ), hence that may be a reason why this BMS has SOC errors.
Could someone please post some high resolution photos of this BMS without the aluminium faceplates? I did disassemble the one I have but I was stupid enough to not take photos
I would be interested in searching for a way to increase the accuracy of the BMS soc estimation. Maybe increasing the shunt resistor values to 200 - 250 micro ohms(with the consequence of more heat generation in the BMS) and calibrate it afterwards using the current calibration function, but knowing the IC responsible for the shunt readout would be useful. I ordered a new BMS to tinker on but it will take some time until it arrives and I am a bit eager to get started on the calculations.
Thank you!
Thank you!
