teckersley
- Dec 30, 2022
- 33
I am using a JKBMS JK-B2A24S and trying to use their 2.3" power board active switch display below. Everything seems to work fine. It plugs in directly to the BMS and it turns the BMS off and on. The problem I am having is that the display screen turns off (not the BMS) after only a minute or so. I would like it to say on until I turn off the BMS.
1) does anyone know if there is a way to keep the display active?
2) if not, what other small screes can be used with this BMS? is there an alternative plug in display? Need a relatively small one
Thanks
Thanks
